crwdns2959928:0crwdne2959928:0 ↓Use this guide to replace the trigger assembly in your Ryobi P235 Impact driver if power isn’t getting to the motor while using a fully charged battery.
The trigger assembly is what regulates how much power gets to the motor and what direction the motor spins.
When you reach step 7 and 8, the wires are soldered to the motor so a soldering iron will need to be used to disconnect them from the old trigger assembly and then reattach them to the new one.
Push in both push tabs on the battery at the same time.
Pull the battery away from the drill housing while holding in both tabs.
Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
Open the housing with the data label facing up.
Lift the trigger mechanism and other internal components out of the housing assembly.
Use a soldering iron to remove the black and red wires connecting the trigger assembly to the motor.
To reassemble your device, follow these instructions in reverse order starting at step 6.
Is the trigger what makes this a brushless motor? Is it possible for the trigger to cause the battery to drain down completely overnight?
Netgazer - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
