Ryobi P202 Gear Select Switch Replacement
  1. Ryobi P202 Gear Select Switch Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ryobi P202 Gear Select Switch Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ryobi P202 Gear Select Switch Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The battery can shock you. Only touch plastic, non-conductive components.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Ryobi P202 Gear Select Switch Replacement, Right Side Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ryobi P202 Gear Select Switch Replacement, Right Side Case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
  3. Ryobi P202 Gear Select Switch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ryobi P202 Gear Select Switch Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the casing from the drill body.
    • Take the casing completely off the drill body to gain access to the interior of the drill.
    • The Ryobi P202 casing has Part #: 200690001
  4. Ryobi P202 Gear Select Switch Replacement, Level Gauge: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ryobi P202 Gear Select Switch Replacement, Level Gauge: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ryobi P202 Gear Select Switch Replacement, Level Gauge: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the Drill 180 degrees so that the top is facing you.
    • Lift the level gauge out from the top corner of the drill.
    • The level gauge is Part #: 3000909
  5. Ryobi P202 Gear Select Switch Replacement, Gear Select Switch: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ryobi P202 Gear Select Switch Replacement, Gear Select Switch: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the gear switch upwards from the top of the drill head.
    • The gear switch is Part #: 341098001
Joseph Eckstein
crwdns2935283:004/07/15crwdne2935283:0
1 596 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-6, Forte Spring 2015 crwdns2935289:0Cal Poly, Team 17-6, Forte Spring 2015crwdne2935289:0
CPSU-FORTE-S15S17G6
crwdns2942667:0crwdne2942667:0 1,006
