Ryobi D620H Motor Brush Replacement
  1. Ryobi D620H Motor Brush Replacement, Right Side Case Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the drill so that the screws face upwards.
    • Use the Torx T20 screwdriver to remove all nine screws.
  2. Ryobi D620H Motor Brush Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ryobi D620H Motor Brush Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the end of an opening tool between the right and left sides of the drill to pry the right side of the case.
    • Remove the right side case to expose the inside of the drill.
  3. Ryobi D620H Motor Brush Replacement, Motor Brush: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The motor brushes are located on the rotating armature of the motor.
    • Look for the large dark gray metal housing in the center of the body of the drill, this is the motor.
    • The armature of the motor by finding the chuck and the transfer gears, and then look at the other end of the motor. There is a small copper barrel (armature) that is likely colored dark gray from the carbon brushes rubbing against the armature.
    • On the top and bottom of the armature (small copper barrel), there are brass spring-loaded brackets holding blocks of carbon against the armature; these blocks are the motor brushes.
  4. Ryobi D620H Motor Brush Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ryobi D620H Motor Brush Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the brass spring-loaded bracket from the case using a PH1 screwdriver and remove them from the case and armature.
    • The motor brush will likely partialy self-eject from the brass brackets.
    • It is highly recommended to replace one motor brush at a time to not mix up the wiring.
    • Unscrewing the brush brackets is the same for both top and bottom.
  5. Ryobi D620H Motor Brush Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the two connections (circled in red) gently from their terminals.
    • The longer white wire connects to the left side terminal and the shorter white wire connected to the brush connects to the right side terminal
    • Remove the composite shim under the bracket.
  6. Ryobi D620H Motor Brush Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove screws and disconnect the two terminals circled in red on the bottom brush bracket.
    • Remove the longer black wire that connects to the left side terminal
    • Remove the shorter white wire connected to the brush that connects to the right side terminal
    • Remove composite shim under the bracket.
  7. Ryobi D620H Motor Brush Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ryobi D620H Motor Brush Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This process is identical for the top and bottom brushes as they are mirrored.
    • Remove the right-side wire from terminal. (The wire that connects to the brush).
    • Pull the brush out of the brackets gently. It shouldn't require much force.
  8. Ryobi D620H Motor Brush Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ryobi D620H Motor Brush Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the new coil spring on the new bracket.
    • Slide the motor brush wire into the bracket and connect it to the right-side terminal.
    • Reconnect the longer white wire on the top brackets left side terminal by firmly and steadily pushing down.
    • Reconnect the longer black wire on the bottom bracket left side terminal by firmly and steadily pushing down.
    • Replace the composite shim under the brackets.
    • Screw both brackets down.
You've successfully replaced the motor brushes on your Ryobi Hammer Drill!
Jacob da Ponte
crwdns2935283:010/30/23crwdne2935283:0
469 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-2, Petersen Fall 2023 crwdns2935289:0UMass Dartmouth, Team 1-2, Petersen Fall 2023crwdne2935289:0
UMASSD-PETERSEN-F23S1G2
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 857
