Ryobi CSB135L Power Cord Replacement
  1. Ryobi CSB135L Power Cord Replacement, Power Cord: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the saw on a flat surface.
    • Make sure the saw is unplugged and unpowered.
  2. Ryobi CSB135L Power Cord Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ryobi CSB135L Power Cord Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six M4x16mm Phillips screws and the two M4.5x35mm screws using a Phillips #2 screwdriver.
    • Remove the front facing half of the handle assembly exposing the internals of the saw.
  3. Ryobi CSB135L Power Cord Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ryobi CSB135L Power Cord Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the handle assembly locate the trigger switch and wire nut in the saw.
    • Remove the screw from the black wire of the power cord using a Phillips screwdriver. Then remove the wire.
    • Loosen the wire nut and remove the neutral wire from the power cord.
  4. Ryobi CSB135L Power Cord Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the power cord from the saw.
    • To insert the replacement power cord, insert the black wire of the cord into the trigger switch and tighten the screw. Take the neutral/white wire of the new cord and insert it into the wire nut and tighten the nut.
    • Wire strippers may be needed when installing the new power cord to expose the copper wire.
Nathanael Winchell
crwdns2935283:003/16/23crwdne2935283:0
689 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 7-3, Ryckebusch Spring 2023 crwdns2935289:0UMass Dartmouth, Team 7-3, Ryckebusch Spring 2023crwdne2935289:0
UMASSD-RYCKEBUSCH-S23S7G3
crwdns2942667:0crwdne2942667:0 354
