Ryobi CSB135L Laser Replacement
  1. Ryobi CSB135L Laser Replacement, Motor Housing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three M4.5 x 35mm screws that hold the motor housing to the blade housing using a Phillips screwdriver.
    • Although not required for motor housing removal, the two M4 x 16 mm Phillips head screws must be removed for access to the top of the motor.
  2. Ryobi CSB135L Laser Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three M3.5 x 16 mm screws that hold on the laser cover using a Phillips screwdriver.
    • The wires that power the laser prevent the motor housing from coming off, so the laser must be removed.
  3. Ryobi CSB135L Laser Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the motor housing (green plastic) from the blade housing (gray plastic) using a metal spudger or any small pry bar.
  4. Ryobi CSB135L Laser Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fully remove the motor housing and blade cover to expose the motor and laser.
  5. Ryobi CSB135L Laser Replacement, Laser: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Regardless of the assembly state of the saw, remove the M4 x 16 mm screws that hold the two pieces of the handle together using a Phillips screwdriver.
  6. Ryobi CSB135L Laser Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the laser from the handle.
  7. Ryobi CSB135L Laser Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the laser that is woven through the plastic of the saw's handle.
Nathanael Winchell
crwdns2935283:003/16/23crwdne2935283:0
689 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 7-3, Ryckebusch Spring 2023 crwdns2935289:0UMass Dartmouth, Team 7-3, Ryckebusch Spring 2023crwdne2935289:0
UMASSD-RYCKEBUSCH-S23S7G3
crwdns2942667:0crwdne2942667:0 330
