Ryobi CSB125 Power Cord Replacement
crwdns2869540:0crwdne2869540:0: 2,4 тыс.
16
72
2 385
crwdns2959984:0crwdne2959984:0: 5
crwdns2959974:05crwdne2959974:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:015crwdne2931287:0
This guide will show you how to properly install a new power cord to your Ryobi CSB125 circular saw. If the cord is plugged into a power source but the saw fails to make any movement when the trigger is pressed in, then most likely the power cord has gone bad. This troubleshooting page will help diagnose any potential problems occurring due to a faulty power cord. In the event that a new power cord is needed, this guide will show the steps to properly install a new one. The only tools you will need are a Phillips #2 screwdriver and a pair of wire strippers. This guide will cover how to access the internal wires from the power cord.
    1. Ryobi CSB125 Power Cord Replacement, Power Cord: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place the saw down on a flat surface with the motor facing up.
      • Make sure that the saw is unplugged from any power source.
    2. Ryobi CSB125 Power Cord Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ryobi CSB125 Power Cord Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the Phillips #2 screwdriver to remove the five M4x16mm screws.
    3. Ryobi CSB125 Power Cord Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the Phillips #2 screwdriver to remove the two M45x35mm screws.
    4. Ryobi CSB125 Power Cord Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ryobi CSB125 Power Cord Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • To remove the plug from the saw you will need to disconnect the two wires that come from the plug.
      • Remove the black wire by unscrewing it from the trigger switch using the Phillips #2 screwdriver.
      • Remove the white wire by twisting off the plastic wire nut to separate the two white wires.
    5. Ryobi CSB125 Power Cord Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the plug from the saw.
      • You may have to use the wire strippers to expose the copper on the new plug.
      • It is important that the wires are properly run in their tracks. Failure to do so could result in pinching a wire, which could damage the plug.
crwdns2935229:05crwdne2935229:0
Curtis Melo
crwdns2935283:010/31/19crwdne2935283:0
1 093 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S2-G1, Barthe Fall 2019 crwdns2935289:0UMass Dartmouth, Team S2-G1, Barthe Fall 2019crwdne2935289:0
UMASSD-BARTHE-F19S2G1
crwdns2936753:030crwdne2936753:0 72
crwdns2959996:0crwdne2959996:0 2,385
