crwdns2959928:0crwdne2959928:0 ↓This guide will show you how to properly install a new blade to your Ryobi CSB125 circular saw. When performing cuts, if there is a burning smell then most likely the blade is either dirty or dull. In this case, the blade should be replaced with a new one. This troubleshooting page will help diagnose any potential problems occurring due to a faulty blade. In the event that a new blade is needed, this guide will show the steps to properly install a new one. The only tool you will need is a 7”/32 allen key.
Place the saw down on a flat surface with the blade facing up.
Use the 7”/32 allen key to loosen the 5/16-18 x 9/16 in. blade screw.
Remove the 5/16-18 x 9/16 in. blade screw, spring washer, and the outer blade washer.
I think this is the wrong title.these instructions show how to remove the blade NOT replace it.
Prenston Gale Sr - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
