Is your vacuum bumping into everything? Replacing the bumpers may solve the problem.
Flip the vacuum over so that the wheels are facing you.
Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
Lift the battery cover up to reveal the battery.
Remove the battery.
Remove the eight 10 mm Phillips #1 screws.
Hold the front bumper and pull it off.
Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
