Royal P50 Electric Pencil Sharpener Blades Replacement
  1. Royal P50 Electric Pencil Sharpener Blades Replacement, Blades: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn over your pencil sharpener so the bottom is facing up.
    • Use a spudger to remove the rubber screw covers.
    • Use a Phillips #1 screwdriver to remove the screws from the bottom of the device.
  2. Royal P50 Electric Pencil Sharpener Blades Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take off the white cover by sliding it up along the mechanism. This will reveal both the blade mechanism and wiring in the back of the sharpener.
  3. Royal P50 Electric Pencil Sharpener Blades Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your hands, pry off the black disk-like component seen highlighted here.
  4. Royal P50 Electric Pencil Sharpener Blades Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Royal P50 Electric Pencil Sharpener Blades Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take note of the metal rod that is now exposed and directly connected to the blade; this is what we aim to remove.
    • Underneath the blades you will see a rectangular opening and a portion of that same rod.
  5. Royal P50 Electric Pencil Sharpener Blades Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Royal P50 Electric Pencil Sharpener Blades Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the same Phillips screwdriver, push the rod upwards by lodging the screwdriver where the rod rests, beneath the metal plate.
    • There will now be a large metallic rod sticking out of the top of the blade.
  6. Royal P50 Electric Pencil Sharpener Blades Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Finally, remove the rod, and the blade will come right out.
    • Inserting the replacement blades should be done the same way as the process of removal but this time in reverse.
    • Once the blade has been secured, place and screw everything back into their respective locations.
  7. Royal P50 Electric Pencil Sharpener Blades Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Your pencil sharpener should work as good as new now!
    • Happy sharpening!
Joshua Seger
crwdns2935283:001/27/25crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 1-5, Ribeiro Spring 2025 crwdns2935289:0CSU Los Angeles, Team 1-5, Ribeiro Spring 2025crwdne2935289:0
CSULA-RIBEIRO-S25S1G5
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 97
