Royal Heat RS-100 Front Panel Assembly Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Royal Heat RS-100 Front Panel Assembly Replacement, Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the power cord.
    • Flip the device over so the bottom is facing up.
    • Remove the two 10mm screws holding the back panel using a Phillips #2 screwdriver.
  2. Royal Heat RS-100 Front Panel Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Royal Heat RS-100 Front Panel Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Royal Heat RS-100 Front Panel Assembly Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the Flathead Screw driver parallel with the gap between the back and the heater body, then twist until the two parts of panel are separated. You may have to do this on four sides of the panel.
    • Remove the front panel by pulling them apart. The front panel should come out easily.
  3. Royal Heat RS-100 Front Panel Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two dial caps from the two switches by lifting them up.
Long Tran
crwdns2935283:010/14/13crwdne2935283:0
205 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 11-35, Amido Fall 2013 crwdns2935289:0Cal Poly, Team 11-35, Amido Fall 2013crwdne2935289:0
CPSU-AMIDO-F13S11G35
crwdns2935297:013crwdne2935297:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 106
