Rowenta Focus Power Assembly Replacement
crwdns2942287:0crwdne2942287:0This guide will provide a step-by-step walkthrough on how to replace the power assembly of a Rowenta Focus DW5080. This is useful for troubleshooting a faulty power cord and allowing the iron to have power again. This part should only be replaced if the outlet the cord was plugged into has been checked and works. The light on the iron should not be on and the iron should not be getting warm if this part is damaged.
Prior to beginning this repair, be sure the device is turned off and unplugged.
crwdns2944105:0crwdne2944105:0
Using a T20 screwdriver, remove the 20 mm screw on the back of the iron.
Pry the back cover of the iron off using a metal spudger.
Remove the back cover, exposing the wiring in the iron.
Remove the frontmost (main) power cord to give access to inner wiring and accessories.
Pull out the motherboard inside handle of iron.
Remove the 4-pronged adaptor from inside the iron by grabbing the black plastic piece and pulling straight out.
What do you replace? It did not say when the heating coil was replaced!
and then what?
To reassemble your device with new power supply, follow these instructions in reverse order.
Thanks... Where we can get parts
