Rowenta Focus Material Setting Knob Replacement
  1. Rowenta Focus Material Setting Knob Replacement, Power Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rowenta Focus Material Setting Knob Replacement, Power Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a T20 screwdriver, remove the 20 mm screw on the back of the iron.
    • Unplug iron before removing cover and make sure the iron is cool before beginning the repair.
  2. Rowenta Focus Material Setting Knob Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rowenta Focus Material Setting Knob Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rowenta Focus Material Setting Knob Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the back cover of the iron off using a metal spudger.
    • Remove the back cover, exposing the wiring in the iron.
  3. Rowenta Focus Material Setting Knob Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rowenta Focus Material Setting Knob Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the frontmost (main) power cord to give access to inner wiring and accessories.
    • Leave the other cords attached to the main cord.
  4. Rowenta Focus Material Setting Knob Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rowenta Focus Material Setting Knob Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the motherboard inside handle of iron.
    • Keep it attached to main power cord and other components.
    Where I can buy this part in India?
    Baiju Vasavan - crwdns2934203:0crwdne2934203:0
  5. Rowenta Focus Material Setting Knob Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rowenta Focus Material Setting Knob Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rowenta Focus Material Setting Knob Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 4-pronged adaptor from inside the iron by grabbing the black plastic piece and pulling straight out.
    What do you replace? It did not say when the heating coil was replaced!
    Africa So - crwdns2934203:0crwdne2934203:0
  6. Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the metal spudger into the space between the spray/steam button piece and the rest of the iron.
    • Using the metal spudger for leverage, pry the piece away from the rest of the iron until it can be lifted out.
    • Lift out the piece.
  7. Rowenta Focus Material Setting Knob Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rowenta Focus Material Setting Knob Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rowenta Focus Material Setting Knob Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Replace with an identical part by inserting it into the space.
  8. Rowenta Focus Material Setting Knob Replacement, Heating Element/Soleplate: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rowenta Focus Material Setting Knob Replacement, Heating Element/Soleplate: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the T20 screwdriver, remove the 20 mm screw that was under the steam and spray button.
  9. Rowenta Focus Material Setting Knob Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rowenta Focus Material Setting Knob Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unhook the clips on the top of the metal piece.
    • Using the metal spudger, remove the metal piece on the tip of the iron.
  10. Rowenta Focus Material Setting Knob Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rowenta Focus Material Setting Knob Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the T20 screwdriver, remove the 20 mm screw that was under the metal piece on the tip of the iron.
  11. Rowenta Focus Material Setting Knob Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rowenta Focus Material Setting Knob Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rowenta Focus Material Setting Knob Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the T20 screwdriver, remove the two 20 mm screws on either side of the back of the iron.
  12. Rowenta Focus Material Setting Knob Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rowenta Focus Material Setting Knob Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rowenta Focus Material Setting Knob Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the iron up using the handle to completely detach the soleplate.
  13. Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the T20 screwdriver, remove both of the 20mm screws on the underside of the iron.
  14. Rowenta Focus Material Setting Knob Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rowenta Focus Material Setting Knob Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the iron over and pull the knob off.
    • Be careful not to tip the iron after removing the knob; there are small springs in the white piece underneath the knob.
    Bonjour ou se trouve justement le ressort sous le bouton ? ou le placer ?
    Adi De Sousa - crwdns2934203:0crwdne2934203:0
Bella Navarro
crwdns2935283:009/03/21crwdne2935283:0
450 crwdns2915208:0crwdne2915208:0
University of Alabama, Team 2-3, Bedsole Fall 2021 crwdns2935289:0University of Alabama, Team 2-3, Bedsole Fall 2021crwdne2935289:0
UA-BEDSOLE-F21S2G3
Nice pics, came apart easily with this guide. Just need a note on the small ball bearing which I assume goes somewhere on the steam valve?
Step - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 50
crwdns2942667:0crwdne2942667:0 1,562
