This guide explains how to completely teardown the Rosewill NEON M62 mouse. This repair should be performed when something needs to be replaced internally.
            Place the mouse so the bottom is facing upwards.
            Remove the plastic skates.
            Remove the two 5 mm screws with a Phillips #00 screwdriver.
            Use the opening tool along the side of the mouse to open up it.
            Loosen the top and bottom half of the mouse with the opening tool, and slowly pull up the bottom half of the mouse.
