This guide demonstrates how to install a roll pin and bearing into a bearing carrier for your Electric Eel 75’ Drain Cleaner Z5K12IC75AF.
Use a vise to compress the roll pin until there is no longer space in the roll pin's slot.
Use a dead blow hammer or mallet to tap down the bearing carrier onto the roll pin until the pin just begins to peek into the bearing channel.
Insert a bearing and the bearing spacer into the bearing channel.
Continue to tap down the bearing carrier until the bearing and spacer are fully secured around the roll pin.
Use a roll pin punch to finish seating the roll pin into place.
