Roland TR-505 Switch-board Replacement
  1. Roland TR-505 Switch-board Replacement, Removing the dials: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roland TR-505 Switch-board Replacement, Removing the dials: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roland TR-505 Switch-board Replacement, Removing the dials: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the dials in front of you carefully pull them up and away from the hide and shaft
  2. Roland TR-505 Switch-board Replacement, Removing the bottom screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove these Philips PH1 screw
    • Not all screws are the same,make sure to keep them organised:-)
  3. Roland TR-505 Switch-board Replacement, Opening the device: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roland TR-505 Switch-board Replacement, Opening the device: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully separate the 2 half’s
    • If it’s not coming apart you may need a plastic pry tool to assist you
    • Once separated:with the ports facing you open the device like a book with the top panel lifted up slightly,make sure to open it to the right
  4. Roland TR-505 Switch-board Replacement, Unplugging the connectors: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully unplug the connectors from their sockets by pulling on the tabs that stick out from the cable
    • Do not pull on the cable itself as you risk pulling the cables out of the connector
  5. Roland TR-505 Switch-board Replacement, Disassembling the top half: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • with the connectors disconnected you can lift the top half away.
    • to take the switchboard off take out these PH 1 Philips screws
    • Thumbs up to Roland for adding arrows to where the screws are on the switch-board:-)
  6. Roland TR-505 Switch-board Replacement, Removing the Switch-board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the switch-board out
HelloMacOS
crwdns2935283:001/24/22crwdne2935283:0
27,039 crwdns2915208:0crwdne2915208:0
crwdns2935297:011crwdne2935297:0
Repair is War on Entropy crwdns2935289:0Repair is War on Entropycrwdne2935289:0
Community
crwdns2931471:031crwdne2931471:0
crwdns2935297:01,549crwdne2935297:0
crwdns2942667:0crwdne2942667:0 195
