Roku 3 Remote Control Buttons Replacement
Isobelle Espiritu
crwdns2944107:0crwdnd2944107:0Isobelle Espiritucrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Huk 30, 2016crwdne2944111:0
crwdns2931287:020crwdne2931287:0
crwdns2937799:0crwdne2937799:0
crwdns2862591:0crwdne2862591:0
crwdns2942287:0crwdne2942287:0
If your remote control buttons are no longer working effectively, this guide will show you how to replace the buttons on your remote.
  1. Roku 3 Remote Control Buttons Replacement, Remote Control Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the remote over so that the buttons are facing down and the end with the wrist strap is nearest your right hand.
    Thank You ! I needed some help getting the back off. I was getting so upset and found this site. The back wouldn't come off but watched this and got it off. YA me ! Not a handy person.?
    Linda Walker - crwdns2934203:0crwdne2934203:0
  2. Roku 3 Remote Control Buttons Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roku 3 Remote Control Buttons Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press and hold the black tab above the battery compartment.
    • While holding down the tab with your left hand, slide down the battery compartment cover with your right hand to remove it.
    Is the black tab also the mute button?
    J-Lyn Estrella - crwdns2934203:0crwdne2934203:0
  3. Roku 3 Remote Control Buttons Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the batteries by placing a finger on one end of the battery and pushing downward while pulling the battery out.
  4. Roku 3 Remote Control Buttons Replacement, Remote Control Buttons: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roku 3 Remote Control Buttons Replacement, Remote Control Buttons: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew one 7 mm Phillips #0 screw from the center of the battery compartment.
  5. Roku 3 Remote Control Buttons Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roku 3 Remote Control Buttons Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pry open the remote using the plastic opening tool.
  6. Roku 3 Remote Control Buttons Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roku 3 Remote Control Buttons Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the top and bottom of the remote casing.
    • Gently place each half of the remote onto a table so that the exteriors are face down.
    • The remote buttons, sensors, and motherboard are not attached to anything inside the remote. Take apart the remote with caution to ensure these components do not accidentally fall out.
  7. Roku 3 Remote Control Buttons Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully flip over the front casing side of the remote so that the buttons drop onto the table.
    • If the buttons do not drop immediately, use your fingers to peal them off the front casing of the remote.
    This article helps me to replace the Roku remote baterry. Thanks lot.
    Katherine Melinda - crwdns2934203:0crwdne2934203:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Isobelle Espiritu
crwdns2935283:010/06/16crwdne2935283:0
591 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-2, Livingston Fall 2016 crwdns2935289:0Cal Poly, Team 15-2, Livingston Fall 2016crwdne2935289:0
CPSU-LIVINGSTON-F16S15G2
Do you have a source for getting replacement buttons? I have volume buttons that don't work and was hoping to fix them/ replace them. Thank you!
Patrick Canady - crwdns2934203:0crwdne2934203:0
Hi Patrick,
I literally just finished successfully fixing my volume-up button.
The replacement part number for the right microswitches is EVQ-P7J01P, available at Digi-Key:
https://www.digikey.com/product-detail/e...
Really inexpensive (around 30 cents each). Pro-tip - to help remove the old switch easily, cut it in half with sharp side-cutters.
Good luck!
Jeff T.
J Thomson -
Where can I find a component layout?
Rey De Castro - crwdns2934203:0crwdne2934203:0
Setuproku provides support for all roku related issue. This article help us to understand the Roku remote control.
setuproku code - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,915
