If your Roku 2 is experiencing problems such as signal failures, freezes, or infinite boot loops, use this guide to replace the motherboard.
The motherboard is the main circuit board allows the Roku 2 to function properly and provides connections and communication to all other devices. A faulty motherboard could result in device shutdowns, overheating, and unresponsive controls.
Before starting this guide, ensure that the Roku 2's power supply is stable. A poor power connection could very well be the cause for random device shutdowns. Other good tests to attempt before replacing the motherboard would be a quick power cycle or a complete factory reset.
Once ready to continue with this guide, ensure to fully disconnect the Roku 2 from its power supply and allow it to cool down for a few minutes.
Heat up the iOpener for 30 seconds in the microwave and place across rubber pads on the back of the device.
Gently use the plastic opening tool to pry the rubber pads off.
Remove the four Phillips #000 screws from the bottom of the case.
Gently remove the under side of the device.
Remove the middle component that is held in place by the top and bottom of the device.
Remove the cover over the A/V ports on the front of the device.
Remove the board from the plastic enclosure.
