This guide will show you how to open your Roconia device to access its internal components.
Flip your device upside down so that the interface is facing downwards.
The device is supported by rubber pieces located at the bottom extremities.
There are screws beneath the rubber pieces that can be removed. Remove all four 1.1 mm Phillips #1 screws by using the Phillips #0 screwdriver.
Turn device over again and pry open the device to remove the cover.
Pull out the cable that is connected to the top cover to fully separate.
