This is a step-by-step guide on replacing the motherboard in the Roconia Q6 Projector. Whether you're upgrading or troubleshooting, follow these instructions to navigate through the process smoothly.
Flip your device upside down so that the interface is facing downwards.
The device is supported by rubber pieces located at the bottom extremities.
There are screws beneath the rubber pieces that can be removed. Remove all four 1.1 mm Phillips #1 screws by using the Phillips #0 screwdriver.
Turn device over again and pry open the device to remove the cover.
Pull out the cable that is connected to the top cover to fully separate.
Remove the 8.8mm screws holding the device in place using the Phillips #0 screwdriver.
Remove the wires attached to the motherboard by pulling them out gently.
