In this guide, we'll walk you through the simple steps of replacing the fan in the Roconia Q6. With just a few basic tools and a little know-how, you can ensure your Roconia Q6 continues to operate smoothly and efficiently.
Flip your device upside down so that the interface is facing downwards.
The device is supported by rubber pieces located at the bottom extremities.
There are screws beneath the rubber pieces that can be removed. Remove all four 1.1 mm Phillips #1 screws by using the Phillips #0 screwdriver.
Turn device over again and pry open the device to remove the cover.
Pull out the cable that is connected to the top cover to fully separate.
Use the opening guide to open the device. Once open find the fan located in the back corner of the device
To remove the fan from its holder, simply pull it out.
Remove the sticker on the back of the fan to reveal soldered wires.
Using a soldering iron, desolder the wiring from the fan.
