Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement
  1. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement, How to Open the Rocketfish RF-WHTIB-A Receiver: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 rubber tabs on the bottom side of the receiver.
  2. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four 12 mm screws on the bottom side of the receiver.
    • Use a Phillips #1 screwdriver for this step.
  3. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove top casing from the receiver.
    • The receiver top casing is difficult to remove. Internal clasps may have to be broken in order to remove the top casing (this will not effect the device's function)
  4. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement, Receiver LED Light Chip: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement, Receiver LED Light Chip: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • One 10 mm screw is securing the LED 14.14 chip.
    • Unscrew the chip.
    • Use a Phillips #1 Screwdriver for this step.
  5. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, gently pull the LED plug out of the mother board.
  6. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently feed the LED wire under the power supply to completely remove it from the sender.
    • Remove the faulty LED 14.14 chip from the receiver.
    • You may want to use the tweezers to help pull the LED wire out from beneath the power supply.
To reassemble your device with the new LED light chip, follow these instructions in reverse order.
Once the receiver has been put back together, plug in the device and initiate the connection mode between the sender and receiver to ensure the new LED light chip has been properly assembled.
Caitlin Charlton
crwdns2935283:003/22/15crwdne2935283:0
756 crwdns2915208:0crwdne2915208:0
Baylor, Team 4-2, Williams Spring 2015 crwdns2935289:0Baylor, Team 4-2, Williams Spring 2015crwdne2935289:0
BU-WILLIAMS-S15S4G2
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 2,164
