Roccat Vulcan II Mini Air Keycap Replacement
  1. Roccat Vulcan II Mini Air Keycap Replacement, Keycap: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roccat Vulcan II Mini Air Keycap Replacement, Keycap: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a keycap puller or your fingers to gently pull off the keycap.
    • Avoid using excessive force to avoid damaging the switch.
    • Lift the keycap evenly and straight up from the keyboard.
    • If you are not using a keycap puller you may need to wiggle the cap slightly to loosen it.
    • Clean the keyboard using an air blower and a soft brush to remove any debris or dust between the switches.
    • Align the new keycap with the switch stem, ensuring the small cross-shaped hole at the bottom of the keycap matches the stem. Once aligned, gently press down on the keycap until it snaps securely into place.
    • You'll hear a soft "click" sound or feel resistance when it’s properly seated.
    • Be careful with larger keys (like the spacebar or enter key) as they might have additional stabilizer clips.
Elizabeth
crwdns2935283:010/24/24crwdne2935283:0
226 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-3, Santin Fall 2024 crwdns2935289:0UMass Dartmouth, Team 3-3, Santin Fall 2024crwdne2935289:0
UMASSD-SANTIN-F24S3G3
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 225
