Roborock S7: Cliff sensor replacement
  1. Roborock S7: Cliff sensor replacement, Top cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roborock S7: Cliff sensor replacement, Top cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Begin by removing the front half of the top cover.
    • It is held on by relatively loose latches. They will come free with some force.
    • Do not bend the plastic cover too much. It has some flexibility, but if bent too much, it could deform or snap.
    • Continue by removing the back half of the top cover.
    • Once removing the screws and the plastic bits, it will just pop out.
  2. Roborock S7: Cliff sensor replacement, LiDAR: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock S7: Cliff sensor replacement, LiDAR: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock S7: Cliff sensor replacement, LiDAR: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the rubber caps covering the 2 screws.
    • Remove the screws.
    • Remove the LiDAR cage.
    • Remove the LiDAR screws, then remove the LiDAR.
    • Based on the version of the robot, you might see one of 3 different iterations of the LiDAR. One, that is noticeably smaller, is connected via cable, whereas the other 2 are simply connected by a connector.
  3. Roborock S7: Cliff sensor replacement, Bottom cover, battery and bumper: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock S7: Cliff sensor replacement, Bottom cover, battery and bumper: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock S7: Cliff sensor replacement, Bottom cover, battery and bumper: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 5 screws and side brush, then remove the bottom panel.
    • Remove the battery. Pull it up and over from left to right, then disconnect the connector.
    • Be careful with the connector. I've had cases where people had torn them off by yanking at the cable instead of pressing on and pulling the connector.
    • Remove the marked screws, then remove the top cover of the bumper, then the bumper itself.
  4. Roborock S7: Cliff sensor replacement, Side brush motor and VibraRise lift wire: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock S7: Cliff sensor replacement, Side brush motor and VibraRise lift wire: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock S7: Cliff sensor replacement, Side brush motor and VibraRise lift wire: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue by removing the side brush motor.
    • Move further below, then remove the screws. The 2 holes marked by arrows have screws within them. The smaller screws are PH1 and the bigger are PH2. After removing the screws, remove the side panel.
    • Remove the wire from the plastic housing. Angled tweezers recommended.
  5. Roborock S7: Cliff sensor replacement, Check on your feline assistant.: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Shhh, she's sleeping.
  6. Roborock S7: Cliff sensor replacement, Chassis and main brush: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock S7: Cliff sensor replacement, Chassis and main brush: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock S7: Cliff sensor replacement, Chassis and main brush: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screws marked in image 1.
    • Now remove the screws in image 2, then remove the main brush assembly. There is no need to remove the brush cover or the brush itself. You simply pull it out.
    • Remove the 2 screws hidden by the main brush assembly.
  7. Roborock S7: Cliff sensor replacement, Latches on the back: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roborock S7: Cliff sensor replacement, Latches on the back: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unlatch these 2 latches.
  8. Roborock S7: Cliff sensor replacement, Finito: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • And voila, it's open.
  9. Roborock S7: Cliff sensor replacement, Diagnose the faulty cliff sensor: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock S7: Cliff sensor replacement, Diagnose the faulty cliff sensor: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock S7: Cliff sensor replacement, Diagnose the faulty cliff sensor: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Begin by finding out which of your cliff sensors is dead. I don't have a scientific method here, but I start by checking the one that is most commonly faulty.
    • It's the cliff sensor that is next to the suction fan. Remove the suction fan cover, then the suction fan itself.
    • The reason this one is usually faulty is: If the suction fan swallows any water at all, some amount will almost certainly land within this cliff sensor, causing damage.
  10. Roborock S7: Cliff sensor replacement, Remove the cliff sensor: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock S7: Cliff sensor replacement, Remove the cliff sensor: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock S7: Cliff sensor replacement, Remove the cliff sensor: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slip something thin in the gap. If you own an iFixit Jimmy, this is where it comes in very handy.
    • You can also use a hammer to tap the cliff sensor out of place, but that risks breaking the plastic housing.
  11. Roborock S7: Cliff sensor replacement, Disassemble the cliff sensor: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock S7: Cliff sensor replacement, Disassemble the cliff sensor: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock S7: Cliff sensor replacement, Disassemble the cliff sensor: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take the cliff sensor apart. It is held together by 2 latches on both sides. Fold those out, then slide the 2 halves apart.
    • In my case, the damage was apparent.
  12. Roborock S7: Cliff sensor replacement, Replace the damaged part, then reassemble the sensor: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roborock S7: Cliff sensor replacement, Replace the damaged part, then reassemble the sensor: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Prepare a replacement and fit it into the cliff sensor assembly.
    • Once you have it fitted properly, re-assemble the cliff sensor chassis.
  13. Roborock S7: Cliff sensor replacement, Check on your feline assistant.: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Why is she sitting like that, though?
  14. Roborock S7: Cliff sensor replacement, Soldering: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock S7: Cliff sensor replacement, Soldering: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock S7: Cliff sensor replacement, Soldering: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now the fun part: Soldering!
    • Solder the wires together, in my case it was simple. Blue on blue, white on white.
    • I think (but I am not certain, as I am not an electrician) that white is the positive while blue is the negative. Or it might not matter at all. I don't know.
    • This is a pretty low difficulty soldering task.
  15. Roborock S7: Cliff sensor replacement, Put it back where it belongs.: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fit the cliff sensor back where it fits, then test the device to see if the error persists.
  16. Roborock S7: Cliff sensor replacement, Caution!: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When reassembling the device, ensure that no cables cover this (or any other) screw hole.
To reassemble your device, follow instructions from step 8 in reverse order.
DegenFixer
crwdns2935283:009/18/24crwdne2935283:0
4.649 crwdns2915208:0crwdne2915208:0
Hi,
An object got lodged in the wheel well of my S7 and now it can't sit and vacuum normally. Could you please tell me which parts I need to remove to get there? Do I need to remove the water tank parts?
taye1234 - crwdns2934203:0crwdne2934203:0
Where did you get the actual sensor to replace? I don't know what that part is or where to find it. Thanks!
Casey Johle - crwdns2934203:0crwdne2934203:0
Look for s7 cliff sensor in google, amazon or alibaba...
Michael Büssow - crwdns2934203:0crwdne2934203:0
You're so lucky... nobody can fix that whithout your feline assistant !
Thanks anyway :)
Pika Ksou - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 177
crwdns2936753:030crwdne2936753:0 633
crwdns2942667:0crwdne2942667:0 3,709
