Roborock S5 Laser Distance Sensor Motor Replacement
  1. Roborock S5 Laser Distance Sensor Motor Replacement, Laser Distance Sensor Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock S5 Laser Distance Sensor Motor Replacement, Laser Distance Sensor Motor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock S5 Laser Distance Sensor Motor Replacement, Laser Distance Sensor Motor: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power down your Roborock S5.
    • Place it on a flat work surface with the power buttons facing toward you.
    • Use an opening tool to carefully pry under the section of the top panel with the buttons.
    • Gently pull upward to snap the panel off the top of the vacuum. It is secured in place by five snaps that you will need to release to remove the panel.
    • This can take some force, and the snaps can be quite loud. Be careful not to break the panel.
  2. Roborock S5 Laser Distance Sensor Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock S5 Laser Distance Sensor Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock S5 Laser Distance Sensor Motor Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the six 9 mm screws securing the other half of the top panel that covers the dust bin.
    • Remove the two hinge covers to free the other top panel.
    • Gently lift the other half of the top panel off of the robot vacuum.
  3. Roborock S5 Laser Distance Sensor Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roborock S5 Laser Distance Sensor Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry off the rubber stoppers covering the three 12 mm screws that secure the Laser Distance Sensor housing cover.
  4. Roborock S5 Laser Distance Sensor Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock S5 Laser Distance Sensor Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock S5 Laser Distance Sensor Motor Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the three 12 mm screws holding the Laser Distance Sensor housing cover in place.
    • Use the same Phillips #2 screwdriver to remove the two 9 mm screws securing the Laser Distance Sensor housing cover.
    • Gently lift the cover off of the sensor.
  5. Roborock S5 Laser Distance Sensor Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock S5 Laser Distance Sensor Motor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock S5 Laser Distance Sensor Motor Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the four 9 mm screws holding the Laser Distance Sensor in place.
    • Gently lift it out of the robot vacuum.
  6. Roborock S5 Laser Distance Sensor Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roborock S5 Laser Distance Sensor Motor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the Laser Distance Sensor over so the backside is facing up.
    • Squeeze the tab against the connector, and pull the connector straight up from the socket to disconnect the power cable.
  7. Roborock S5 Laser Distance Sensor Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock S5 Laser Distance Sensor Motor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock S5 Laser Distance Sensor Motor Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the Laser Distance Sensor housing back over.
    • Use a spudger to detach the plastic cord from the motor that connects it to the laser.
    • Use a Phillips #1 screwdriver to remove the two 4 mm screws attaching the motor to the housing.
  8. Roborock S5 Laser Distance Sensor Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roborock S5 Laser Distance Sensor Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the orange gear out of the housing to remove it.
Jacob Searcy
crwdns2935283:009/13/23crwdne2935283:0
971 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-1, Virtue Fall 2023 crwdns2935289:0Western Carolina University, Team 1-1, Virtue Fall 2023crwdne2935289:0
WCU-VIRTUE-F23S1G1
crwdns2936753:07crwdne2936753:0 45
crwdns2936753:030crwdne2936753:0 182
crwdns2942667:0crwdne2942667:0 5,690
