Roborock Q5 Suction Motor Replacement
  1. Roborock Q5 Suction Motor Replacement, Side Brush: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off your Roborock and place the device on a flat surface with the wheels facing up.
    • Position the robot so the five-pronged side brush is on the bottom right side.
  2. Roborock Q5 Suction Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roborock Q5 Suction Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #2 screwdriver to loosen the single captive side brush screw.
    • The screw is attached to the side brush so they cannot be separated.
  3. Roborock Q5 Suction Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roborock Q5 Suction Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the side brush up and off.
  4. Roborock Q5 Suction Motor Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock Q5 Suction Motor Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock Q5 Suction Motor Replacement, Battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips screwdriver to remove the seven 15 mm screws from the bottom panel.
  5. Roborock Q5 Suction Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock Q5 Suction Motor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock Q5 Suction Motor Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift off the bottom panel cover.
    • If the bottom panel is stuck, use a plastic spudger along the edges to gently lift it out of place, then remove it by hand.
  6. Roborock Q5 Suction Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock Q5 Suction Motor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock Q5 Suction Motor Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the two white straps to lift the battery out slightly to reveal the battery connector.
    • The battery is still connected to the robot vacuum. Take care not to strain the battery cable.
  7. Roborock Q5 Suction Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock Q5 Suction Motor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock Q5 Suction Motor Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using moderate pressure, squeeze and pull on the four-wire connector to disconnect the battery from the robot vacuum.
  8. Roborock Q5 Suction Motor Replacement, Suction Motor: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock Q5 Suction Motor Replacement, Suction Motor: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock Q5 Suction Motor Replacement, Suction Motor: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 10 mm Phillips screws that secure the side brush motor.
    • Gently lift the side brush motor up and out of its housing.
  9. Roborock Q5 Suction Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roborock Q5 Suction Motor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the eight 11 mm Phillips screws that secure the front sensor panel cover.
  10. Roborock Q5 Suction Motor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roborock Q5 Suction Motor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the thin black front sensor panel cover bracket.
    • Gently pull the front sensor panel cover away from the robot.
  11. Roborock Q5 Suction Motor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove one 14 mm screw from the battery housing.
    • Use a Phillips #2 screwdriver to remove the eleven deep-set 14 mm screws from the bottom panel.
  12. Roborock Q5 Suction Motor Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roborock Q5 Suction Motor Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully flip the device to place it with the wheels down.
    • Pinch the two dustbin retaining tabs together and pull up on the dustbin to remove it.
  13. Roborock Q5 Suction Motor Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roborock Q5 Suction Motor Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 15 mm Phillips screws that secure the front panel cover.
  14. Roborock Q5 Suction Motor Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock Q5 Suction Motor Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock Q5 Suction Motor Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up the top case.
    • Lift and remove the top case.
  15. Roborock Q5 Suction Motor Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Roborock Q5 Suction Motor Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the suction motor from its housing at the top of the robot.
  16. Roborock Q5 Suction Motor Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Roborock Q5 Suction Motor Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Roborock Q5 Suction Motor Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the white suction motor connector and pull it directly out of its port.
    • Do not pull on the wires.
Jon Panaro
crwdns2935283:001/29/24crwdne2935283:0
351 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 18-1, Watkins Spring 2024 crwdns2935289:0Austin Community College, Team 18-1, Watkins Spring 2024crwdne2935289:0
AUSTINCC-WATKINS-S24S18G1
crwdns2942667:0crwdne2942667:0 398
