Rival Mini Chopper MC-67BL Turning Gears Replacement
  1. Rival Mini Chopper MC-67BL Turning Gears Replacement, Turning Gears: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rival Mini Chopper MC-67BL Turning Gears Replacement, Turning Gears: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Twist the plastic lid counterclockwise to unlock it.
    • Lift the lid to remove it from the container.
  2. Rival Mini Chopper MC-67BL Turning Gears Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the blade from the container.
    • For reassembly, the teeth on the metal shaft line up with slots on the inside of the plastic hole.
  3. Rival Mini Chopper MC-67BL Turning Gears Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With your hand, twist the container counter-clockwise until it unlocks from the base. Remove the container by lifting it straight up.
  4. Rival Mini Chopper MC-67BL Turning Gears Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers to pry out the two rubber feet from the bottom cover of the base.
    • The two feet furthest from the button tower contain screws. The other two feet do not.
  5. Rival Mini Chopper MC-67BL Turning Gears Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rival Mini Chopper MC-67BL Turning Gears Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #2 screwdriver to unscrew the two 12.7-mm screws underneath the rubber feet.
    • Use the same screwdriver to unscrew the 15.88-mm screw from the back of the chopper.
  6. Rival Mini Chopper MC-67BL Turning Gears Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Firmly lift the bottom cover off of the base.
  7. Rival Mini Chopper MC-67BL Turning Gears Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the smaller white gear by lifting it up with your hand.
  8. Rival Mini Chopper MC-67BL Turning Gears Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rival Mini Chopper MC-67BL Turning Gears Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rival Mini Chopper MC-67BL Turning Gears Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base.
    • Grab the gear with your other hand and turn CLOCKWISE. Unlike most screws, the gear is reverse-threaded to allow the blade to spin.
    • Continue turning the gear until completely removed from the blade-shaft.
Roxanne
crwdns2935283:010/17/13crwdne2935283:0
522 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-29, Amido Fall 2013 crwdns2935289:0Cal Poly, Team 4-29, Amido Fall 2013crwdne2935289:0
CPSU-AMIDO-F13S4G29
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 916
