Rival Crock Pot 3120 Disassembly
crwdns2931587:0crwdne2931587:0
  1. Rival Crock Pot 3120 Disassembly, Rival Crock Pot 3120 Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the lid from the crockpot and turn the device over, so that the bottom faces up.
  2. Rival Crock Pot 3120 Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rival Crock Pot 3120 Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to remove the rubber end cap from the bolt on the bottom of the device.
  3. Rival Crock Pot 3120 Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rival Crock Pot 3120 Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a 10mm wrench, remove the metal nut on the bottom of the device.
    • If the bolt connected to the nut appeared to fall into the device this is not an issue. It is connected to a metal bar within the device, so it cannot be lost.
  4. Rival Crock Pot 3120 Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rival Crock Pot 3120 Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your hands, pull the plastic dial off the side of the device.
  5. Rival Crock Pot 3120 Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rival Crock Pot 3120 Disassembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rival Crock Pot 3120 Disassembly: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the nut behind the dial using a 16mm wrench.
    • Once the nut has been loosened you can finish unscrewing it with your hand.
  6. Rival Crock Pot 3120 Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rival Crock Pot 3120 Disassembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rival Crock Pot 3120 Disassembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the bottom panel using your hands.
  7. Rival Crock Pot 3120 Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rival Crock Pot 3120 Disassembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rival Crock Pot 3120 Disassembly: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the power cord out of its slot in the metal casing.
  8. Rival Crock Pot 3120 Disassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rival Crock Pot 3120 Disassembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the rotary switch out from inside the metal casing.
  9. Rival Crock Pot 3120 Disassembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rival Crock Pot 3120 Disassembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rival Crock Pot 3120 Disassembly: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the metal casing up and away from the internal components of the device.
  10. Rival Crock Pot 3120 Disassembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rival Crock Pot 3120 Disassembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rival Crock Pot 3120 Disassembly: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You have now successfully disassembled your device. From here you can troubleshoot or replace any specific parts.
crwdns2935103:0crwdne2935103:0
Cole J. Morrel
crwdns2935283:009/14/22crwdne2935283:0
181 crwdns2915208:0crwdne2915208:0
Tufts University School of Engineering, Team 1-6, Bell Fall 2022 crwdns2935289:0Tufts University School of Engineering, Team 1-6, Bell Fall 2022crwdne2935289:0
TUFTS-BELL-F22S1G6
Reassembly is difficult, the bolt on the bottom is too short!
Johnb - crwdns2934203:0crwdne2934203:0
Bolt is way too short to reassemble this thing and I'm not strong enough to bend the wire bail no matter how I try to do it. Never should have taken the thing apart.
Bob Hodge - crwdns2934203:0crwdne2934203:0
It has been quite a long time since I went through this process but I seem to remember wrapping the threaded part of the bot in dental floss to use as a guide and threaded it through the hole with the crockpot propped up, upright so gravity would aid in assembly (some tire chocks on their sides would work, I think). It took some patience or perhaps stubbornness? But that's how I got it reassembled. I had a really hard time getting the bolt centered and the wire bail part vertical, which made the bolt seem impossibly short, before I tried this approach.
D. Marie Olsen Zito -
The bolt is definitely too short. I was taking it apart to clean it up- had I known, I wouldn't have bothered. I did bend the wire and tied some thread to the bolt- I was determined to not let it get the best of me.
Those heating wires that wrap around the pot are so thin, I was worried about breaking one. When I got it out back together I put some water in it and turn it on low- it was still working.
John Kershisnik - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 1,945
