Rival CM4015 Heating Element Replacement
    1. Rival CM4015 Heating Element Replacement, Base Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rival CM4015 Heating Element Replacement, Base Plate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the three 16 mm tri-point screws from the base plate.
    2. Rival CM4015 Heating Element Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rival CM4015 Heating Element Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the base plate by pressing the plastic body away from the metal plate with your thumbs.
    1. Rival CM4015 Heating Element Replacement, Power Button: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 8mm Phillips screw that attaches the power button to the inside of the coffee maker.
    2. Rival CM4015 Heating Element Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rival CM4015 Heating Element Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a flat head screwdriver to pry the power button from its slot in the body of the device.
      • Make sure the tool is pressed securely under the plastic clip, in order to not break it.
    3. Rival CM4015 Heating Element Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rival CM4015 Heating Element Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Clean both the button and its slot before replacing the power button.
    1. Rival CM4015 Heating Element Replacement, Heating Element: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 8 mm Phillips screws from the plastic body.
    2. Rival CM4015 Heating Element Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rival CM4015 Heating Element Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two 8 mm Phillips screws from the chassis of coffee maker.
      • Pull back the metal backing from the plastic body.
    3. Rival CM4015 Heating Element Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rival CM4015 Heating Element Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rival CM4015 Heating Element Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the four 8 mm Phillips screws from the inner plastic body.
      • You will need a long, thin Phillips screw driver to get this deep into the device.
    4. Rival CM4015 Heating Element Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rival CM4015 Heating Element Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the device upside down and remove the outer plastic body from the device by pulling straight up.
      • Take your time to make sure the thin cables within the device don't tear.
    5. Rival CM4015 Heating Element Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 8 mm Phillips screws from the metal backing.
    6. Rival CM4015 Heating Element Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 4 springs holding the water tubes by squeezing the 2 prongs together.
      • You may also use pliers for this step if the springs are too strong.
    7. Rival CM4015 Heating Element Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Bend the heating element back and forth to wiggle the water tubes loose from the plastic.
Michael Murdock
crwdns2935283:010/06/16crwdne2935283:0
279 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-6, Livingston Fall 2016 crwdns2935289:0Cal Poly, Team 10-6, Livingston Fall 2016crwdne2935289:0
CPSU-LIVINGSTON-F16S10G6
crwdns2942667:0crwdne2942667:0 686
