Ritter (Strix) Kettle 'Fontana' Microcontroller Replacement
  1. Ritter (Strix) Kettle 'Fontana' Microcontroller Replacement, Open kettle base: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ritter (Strix) Kettle 'Fontana' Microcontroller Replacement, Open kettle base: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, be sure to unplug the kettle base.
    • Using Torx screwdriver, open kettle base and remove PCB
    • One can see the five contact rings. From inside they are: Live, Sensor +, Sensor -, Neutral, Ground
  2. Ritter (Strix) Kettle 'Fontana' Microcontroller Replacement, High voltage gap potential problem: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The PCB is not conformally coated, so water splashing around the base can potentially enter and cause damage.
    • The design of the PCB is a bit unfortunate as the high voltage switching regulator is very close to the LDO and microcontroller.
    • Line input
    • Switching regulator
    • LDO and MCU
  3. Ritter (Strix) Kettle 'Fontana' Microcontroller Replacement, High voltage gap problem (2): crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Red circle: Isolation gap between 320VDC and 4.4VDC is about less than 1mm
    • Red arrow: Pulsed 320V (220VAC) switching regulator
    • Blue arrow: 4.4V LDO supply voltage for MCU
  4. Ritter (Strix) Kettle 'Fontana' Microcontroller Replacement, Microcontroller replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using hot air, desolder the TSSOP16 microcontroller labeled "Y12"
    • Unfortunately I was not able to source the microcontroller allone yet. But I could order the entire board for 25€ which is better than nothing. Thank you Ritter
Thomas Widmaier
crwdns2935283:003/05/13crwdne2935283:0
2,137 crwdns2915208:0crwdne2915208:0
crwdns2935297:011crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0326crwdne2931471:0
crwdns2935297:01,685crwdne2935297:0
crwdns2942667:0crwdne2942667:0 507
