Ring Video Doorbell Battery Replacement
  1. Ring Video Doorbell Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ring Video Doorbell Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ring Video Doorbell Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminium plate using the Plastic Opening Tool(s).
    • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
  2. Ring Video Doorbell Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ring Video Doorbell Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ring Video Doorbell Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Do NOT lift the case of all the way, there is still a cable connecting the two pieces.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
Abdulrahman
crwdns2935283:002/20/18crwdne2935283:0
709 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S11-G5, Cheng Spring 2018 crwdns2935289:0USF Tampa, Team S11-G5, Cheng Spring 2018crwdne2935289:0
USFT-CHENG-S18S11G5
crwdns2947412:07crwdne2947412:0
Where do I get a replacement battery?
William Price - crwdns2934203:0crwdne2934203:0
I had an issue where the battery would not charge the light when I was trying to charge the battery flashed bue quickly, I removed the battery and found that the connector was corroded after cleaning it and making sure it was connected correctly the battery then took a full charge and now the bell functions as intended once again.
P.S thanks for the guide :)
David Haras - crwdns2934203:0crwdne2934203:0
Who should the complete unit be sent to for checkup and repairs as it does not work
d.rayyan - crwdns2934203:0crwdne2934203:0
can it be sent to the manufacturers for a replacement
similar to David, I pulled off the battery connector and reattached it, then sealed with some rubber cement. Unit immediately went back online.
Daniel Wise - crwdns2934203:0crwdne2934203:0
Thanks for the guide. NOTE TO OTHERS: the battery connector pins are very fine and fragile, and truly a challenge to reconnect. be sure to try to pry up the connector straight up, else the pins will bend over, then good luck reconnecting!
Dan Elliott - crwdns2934203:0crwdne2934203:0
Front door bell camera no longer works. Tried everything, no results. Is there anything special I need to do to trash the darn thing and install a regular doorbell?
James D Birmingham - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 103
crwdns2936753:030crwdne2936753:0 367
crwdns2942667:0crwdne2942667:0 13,112
