Ring Video Doorbell Camera Replacement
    1. Ring Video Doorbell  Camera Replacement, Camera: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ring Video Doorbell  Camera Replacement, Camera: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ring Video Doorbell  Camera Replacement, Camera: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
      • Pry open the aluminum plate using the Plastic Opening Tool(s).
      • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
    2. Ring Video Doorbell  Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ring Video Doorbell  Camera Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ring Video Doorbell  Camera Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pry open the back case as shown using the Plastic Opening Tool.
      • Disconnect the battery from motherboard by carefully pulling up on the connector.
    3. Ring Video Doorbell  Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ring Video Doorbell  Camera Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ring Video Doorbell  Camera Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unscrew the 9 1 mm screwdrivers using a PH00 Phillips Screwdriver.
      • Carefully detach the motherboard, from the housing unit using your hands.
    4. Ring Video Doorbell  Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ring Video Doorbell  Camera Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the Plating Tool Opener, arefully disconnect the ribbon cable that attaches the camera to the housing.
      • Replace camera, and follow the steps in reverse order to reassemble
    5. Ring Video Doorbell  Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ring Video Doorbell  Camera Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew the two 1 mm screws using the PH00 Philips Screwdriver.
      • Detach the black and red wire connected to the motherboard, using the tweezers, to remove the camera.
Isaiah Wilson
crwdns2935283:002/20/18crwdne2935283:0
231 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S11-G5, Cheng Spring 2018 crwdns2935289:0USF Tampa, Team S11-G5, Cheng Spring 2018crwdne2935289:0
USFT-CHENG-S18S11G5
crwdns2947412:011crwdne2947412:0
What camera should I use to replace a malfunctioning camera in the ring video doorbell? And where do I buy it?
jonathan.byus - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Bump. What camera should I use to replace? (Scratched Lens.) Is the lens you can touch, a lens, or is it just a cover? Mine fell at there is chip right in the center that make the image unusable.
Bobby Diggins - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have a scratch dead center of mine too. Have no clue how it got there as I’m super careful when I take it off to charge. Ugh. did you find out where to buy a replacement?
Kim Townsend - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
What camera should I use to replace? (Scratched Lens.)  I have the right 1st generation with a 740p camera
meanltltoo - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Has anyone found a replacement camera online?
christina.stewart - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 39
crwdns2936753:030crwdne2936753:0 203
crwdns2942667:0crwdne2942667:0 20,941
