In this guide, we will show you how to replace the battery in a Ring Stick Up Cam. You will need a Phillips #00 screwdriver and a plastic opening tool.
Remove the six 6mm Phillips #00 screws from the back of the device.
Pry off the aluminum plate using a plastic opening tool.
Remove the two 6mm Phillips #00 screws that were under the aluminum plate.
Pry off the back cover using a plastic opening tool.
Disconnect the battery power leads using a plastic opening tool.
Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
Remove the three silver 6mm Phillips #00 screws holding the motherboard in the device.
Disconnect the ribbon connector shown in the photo.
Remove the motherboard from the device by hand.
Remove the two black 5mm Phillips #00 screws holding the camera board into the device.
Remove the single silver 10mm Phillips #00 screw holding the camera board into the device.
Remove the three plastic spacers shown in the photo by hand.
Carefully disconnect the camera board from the daughterboard by sliding a plastic opening tool between the camera board and the daughterboard.
Lift the camera board out of the housing using your hand.
Remove the six silver 4.5mm Phillips #00 screws holding the daughterboard into the device.
Use a plastic opening tool to carefully pry the microphone from the housing.
Use your hands to remove the daughterboard containing the microphone from the housing.
Using a plastic opening tool, remove both of the speakers.
