Ring Stick Up Cam Microphone Replacement
    1. Ring Stick Up Cam Microphone Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the six 6mm Phillips #00 screws from the back of the device.
    2. Ring Stick Up Cam Microphone Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pry off the aluminum plate using a plastic opening tool.
    3. Ring Stick Up Cam Microphone Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 6mm Phillips #00 screws that were under the aluminum plate.
    4. Ring Stick Up Cam Microphone Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pry off the back cover using a plastic opening tool.
    5. Ring Stick Up Cam Microphone Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the battery power leads using a plastic opening tool.
    6. Ring Stick Up Cam Microphone Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
    1. Ring Stick Up Cam Microphone Replacement, Camera: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the three silver 6mm Phillips #00 screws holding the motherboard in the device.
    2. Ring Stick Up Cam Microphone Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the ribbon connector shown in the photo.
    3. Ring Stick Up Cam Microphone Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the motherboard from the device by hand.
    4. Ring Stick Up Cam Microphone Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two black 5mm Phillips #00 screws holding the camera board into the device.
      • Remove the single silver 10mm Phillips #00 screw holding the camera board into the device.
    5. Ring Stick Up Cam Microphone Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the three plastic spacers shown in the photo by hand.
    6. Ring Stick Up Cam Microphone Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully disconnect the camera board from the daughterboard by sliding a plastic opening tool between the camera board and the daughterboard.
    7. Ring Stick Up Cam Microphone Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the camera board out of the housing using your hand.
    1. Ring Stick Up Cam Microphone Replacement, Microphone: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the six silver 4.5mm Phillips #00 screws holding the daughterboard into the device.
    2. Ring Stick Up Cam Microphone Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a plastic opening tool to carefully pry the microphone from the housing.
    3. Ring Stick Up Cam Microphone Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your hands to remove the daughterboard containing the microphone from the housing.
Chunyue Liu
crwdns2935283:002/06/19crwdne2935283:0
273 crwdns2915208:0crwdne2915208:0
UC Davis, Team S18-G3, Lore Winter 2019 crwdns2935289:0UC Davis, Team S18-G3, Lore Winter 2019crwdne2935289:0
UCD-LORE-W19S18G3
crwdns2942667:0crwdne2942667:0 3,169
