Ring Stick Up Cam Camera Replacement
crwdns2869540:0crwdne2869540:0: 5,6 тыс.
22
76
5 626
crwdns2955950:0crwdne2955950:0: 5
crwdns2960004:03crwdne2960004:0, crwdns2960008:02crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2955944:0crwdne2955944:0: 20 - 40 crwdns2931279:0crwdne2931279:0
In this guide, we will show you how to replace the camera in a Ring Stick Up Cam. You will need a Phillips #00 screwdriver and a plastic opening tool.
    1. Ring Stick Up Cam Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the six 6mm Phillips #00 screws from the back of the device.
    2. Ring Stick Up Cam Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pry off the aluminum plate using a plastic opening tool.
    3. Ring Stick Up Cam Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 6mm Phillips #00 screws that were under the aluminum plate.
    4. Ring Stick Up Cam Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pry off the back cover using a plastic opening tool.
    5. Ring Stick Up Cam Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the battery power leads using a plastic opening tool.
    6. Ring Stick Up Cam Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
    1. Ring Stick Up Cam Camera Replacement, Camera: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the three silver 6mm Phillips #00 screws holding the motherboard in the device.
    2. Ring Stick Up Cam Camera Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the ribbon connector shown in the photo.
    3. Ring Stick Up Cam Camera Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the motherboard from the device by hand.
    4. Ring Stick Up Cam Camera Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two black 5mm Phillips #00 screws holding the camera board into the device.
      • Remove the single silver 10mm Phillips #00 screw holding the camera board into the device.
    5. Ring Stick Up Cam Camera Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the three plastic spacers shown in the photo by hand.
    6. Ring Stick Up Cam Camera Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully disconnect the camera board from the daughterboard by sliding a plastic opening tool between the camera board and the daughterboard.
    7. Ring Stick Up Cam Camera Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the camera board out of the housing using your hand.
Ao Li
crwdns2935283:002/06/19crwdne2935283:0
245 crwdns2915208:0crwdne2915208:0
UC Davis, Team S18-G3, Lore Winter 2019 crwdns2935289:0UC Davis, Team S18-G3, Lore Winter 2019crwdne2935289:0
UCD-LORE-W19S18G3
crwdns2935297:048crwdne2935297:0
Any ideas where to get a new lens?
Mete Doguoglu - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 76
crwdns2959996:0crwdne2959996:0 5,626
