Ring Stick Up Cam Battery Motherboard Replacement
  1. Ring Stick Up Cam Battery Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the camera so the lens is facing away from you, and the back is facing towards you.
    • Place one hand securely on the base and the other on the stand.
    • Carefully twist your bottom hand counterclockwise until the indicator line reaches the unlock icon.
    Were can I find this motherboard
    Ruben Rodrigues - crwdns2934203:0crwdne2934203:0
  2. Ring Stick Up Cam Battery Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull down to separate the stand from the camera body.
  3. Ring Stick Up Cam Battery Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ring Stick Up Cam Battery Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the camera so the opening containing the battery is toward the ceiling.
    • Squeeze the silver lever labeled "push" and extract the battery from its slot.
  4. Ring Stick Up Cam Battery Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Halberd Spudger
    $2.99
    • Remove the upper and lower silicon covers on the rear panel with your fingers or the hook-end of the halberd spudger.
  5. Ring Stick Up Cam Battery Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 6 mm white screw from the rear panel with the a T3 Torx screwdriver.
  6. Ring Stick Up Cam Battery Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the device so the base is facing upward.
    • Remove the two 6 mm screws from the base (on either side of the QR code) using a Phillips #00 screwdriver.
    • Remove the two 4 mm screws that connect the silver latch on the outside rim using a Phillips #00 screwdriver.
  7. Ring Stick Up Cam Battery Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the silver latch from the base.
    • Remove the front cover.
    • Remove the eight 6 mm screws from the inside panel with a Philips #00 screwdriver.
    • Remove the two 4 mm screws from the inside panel with a Phillips #00 screwdriver.
    “Remove the front cover”. After removing all the screws and silver latch, it still feels like either it’s glued down or snapped on some how. Need more explanation on how to “ remove the front over”.
    Yai Pranivong - crwdns2934203:0crwdne2934203:0
    Hello Yai! You definitely have to put some strength into it! I would take one of the black spudger tools and try to pry it off! There is some sort of additional adhesive you have to work through!
    Vanessa Hasbrouck -
    I'm having the same issue. I'm also unsure where to pry with the spudger.
    Matt Sommer - crwdns2934203:0crwdne2934203:0
  8. Ring Stick Up Cam Battery Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the inside panel open using your hands or a spudger if necessary.
  9. Ring Stick Up Cam Battery Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven 4 mm screws connecting the motherboard to the camera body with a Phillips #00 screwdriver.
  10. Ring Stick Up Cam Battery Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ring Stick Up Cam Battery Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the motherboard from the camera body with the halberd spudger.
  11. Ring Stick Up Cam Battery Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ring Stick Up Cam Battery Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the device to its side.
    • With your fingers, carefully remove the white part of the cord clip from the beige base.
    • Repeat this for the remaining three cords connecting the motherboard to the camera body.
  12. Ring Stick Up Cam Battery Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fold the motherboard downward from the camera body, revealing a white connecting strip.
    • Using the flat end of a spudger, flick the black hinge upward.
    • Pull the white strip out of the slot.
  13. Ring Stick Up Cam Battery Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ring Stick Up Cam Battery Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully insert the spudger underneath gold adhesive at the lower left-hand corner of the motherboard.
    • Gently remove the adhesive cover from the motherboard.
Vanessa Hasbrouck
crwdns2935283:002/24/23crwdne2935283:0
339 crwdns2915208:0crwdne2915208:0
Marist, Team 1-1, Chaterdon Spring 2023 crwdns2935289:0Marist, Team 1-1, Chaterdon Spring 2023crwdne2935289:0
MARS-CHATERDON-S23S1G1
Would like to see a chip identification teardown in the future please 😊
Bryan Watson - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 39
crwdns2936753:030crwdne2936753:0 69
crwdns2942667:0crwdne2942667:0 528
