Ring Stick Up Cam Battery Camera Replacement
    1. Ring Stick Up Cam Battery Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the camera so the lens is facing away from you, and the back is facing towards you.
      • Place one hand securely on the base and the other on the stand.
      • Carefully twist your bottom hand counterclockwise until the indicator line reaches the unlock icon.
    2. Ring Stick Up Cam Battery Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently pull down to separate the stand from the camera body.
    3. Ring Stick Up Cam Battery Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ring Stick Up Cam Battery Camera Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Hold the camera so the opening containing the battery is toward the ceiling.
      • Squeeze the silver lever labeled "push" and extract the battery from its slot.
    1. Ring Stick Up Cam Battery Camera Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      Halberd Spudger
      $2.99
      • Remove the upper and lower silicon covers on the rear panel with your fingers or the hook-end of the halberd spudger.
    2. Ring Stick Up Cam Battery Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 6 mm white screw from the rear panel with the a T3 Torx screwdriver.
    3. Ring Stick Up Cam Battery Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Rotate the device so the base is facing upward.
      • Remove the two 6 mm screws from the base (on either side of the QR code) using a Phillips #00 screwdriver.
      • Remove the two 4 mm screws that connect the silver latch on the outside rim using a Phillips #00 screwdriver.
    4. Ring Stick Up Cam Battery Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the silver latch from the base.
      • Remove the front cover.
      • Remove the eight 6 mm screws from the inside panel with a Philips #00 screwdriver.
      • Remove the two 4 mm screws from the inside panel with a Phillips #00 screwdriver.
    5. Ring Stick Up Cam Battery Camera Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pry the inside panel open using your hands or a spudger if necessary.
    6. Ring Stick Up Cam Battery Camera Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the seven 4 mm screws connecting the motherboard to the camera body with a Phillips #00 screwdriver.
    7. Ring Stick Up Cam Battery Camera Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ring Stick Up Cam Battery Camera Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the motherboard from the camera body with the halberd spudger.
    8. Ring Stick Up Cam Battery Camera Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ring Stick Up Cam Battery Camera Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Rotate the device to its side.
      • With your fingers, carefully remove the white part of the cord clip from the beige base.
      • Repeat this for the remaining three cords connecting the motherboard to the camera body.
    9. Ring Stick Up Cam Battery Camera Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Fold the motherboard downward from the camera body, revealing a white connecting strip.
      • Using the flat end of a spudger, flick the black hinge upward.
      • Pull the white strip out of the slot.
    10. Ring Stick Up Cam Battery Camera Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ring Stick Up Cam Battery Camera Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully insert the spudger underneath gold adhesive at the lower left-hand corner of the motherboard.
      • Gently remove the adhesive cover from the motherboard.
    1. Ring Stick Up Cam Battery Camera Replacement, Camera: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Orient your device so that the interior of the camera body is facing the ceiling.
    2. Ring Stick Up Cam Battery Camera Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 6 mm screws that connect the camera to the camera body using a Phillips #00 screwdriver.
    3. Ring Stick Up Cam Battery Camera Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Grab and twist the camera counterclockwise with your thumb and index finger.
    4. Ring Stick Up Cam Battery Camera Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ring Stick Up Cam Battery Camera Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using your fingers, lift out the camera component including the camera lens and the attached wire.
Nick Tomkins
crwdns2935283:002/24/23crwdne2935283:0
124 crwdns2915208:0crwdne2915208:0
Marist, Team 1-1, Chaterdon Spring 2023 crwdns2935289:0Marist, Team 1-1, Chaterdon Spring 2023crwdne2935289:0
MARS-CHATERDON-S23S1G1
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 105
crwdns2942667:0crwdne2942667:0 7,638
