A step-by-step guide to remove and replace the motion detector in a Ring Spotlight Battery-Powered Cam.
Rotate the camera so the mounting bracket is facing you.
Turn the camera so the mounting bracket is at the bottom.
Press the top button and slide your thumb upward to open the camera.
Remove the two screws located in the middle of the cover with a Phillips #1 screwdriver.
Remove the sticker on the cover.
Remove the 10 screws located around the edge of the cover.
Remove the cover and replace the LED light.
