If you are having trouble with the motion-activated lights and you would like to replace them, follow the 4 steps that are provided. It will take approximately 15-35 minutes.
Remove the top plastic pad by peeling it off with a metal spudger.
Remove the 7 PH00 screws around the four corners with PH00 of the lid.
Use the metal spudger set to break the glue lining and the motion sensor will pop out.
this showed nothing about replacing the light bulb
This is not a complete how to. The directions stop in the middle and don't show the replacement of the LEDs. Also no parts link for the replacement LED strips
very short and sweet i did it
Wait, what? This is incomplete. The directions don't show the replacement of the LED lights.
