Ring Outdoor Security Cam Infrared Sensor Replacement
  1. Ring Outdoor Security Cam Infrared Sensor Replacement, Infrared Sensor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 6 mm Phillips #00 screws from the back on the device.
  2. Ring Outdoor Security Cam Infrared Sensor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry off the aluminum plate using a plastic opening tool.
  3. Ring Outdoor Security Cam Infrared Sensor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the same tool pry the back plate off of the device.
  4. Ring Outdoor Security Cam Infrared Sensor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery power leads using a plastic opening tool.
  5. Ring Outdoor Security Cam Infrared Sensor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
  6. Ring Outdoor Security Cam Infrared Sensor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the ribbon cable carefully at the bottom of the device.
    • Remove the three silver 6 mm Phillips #00 screws from the motherboard.
  7. Ring Outdoor Security Cam Infrared Sensor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the top of the motherboard up and out of the device.
  8. Ring Outdoor Security Cam Infrared Sensor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ring Outdoor Security Cam Infrared Sensor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the silver 5 mm Phillips #00 screw, and the two 10 mm Phillips #00 from the next motherboard.
    • Remove the 3 plastic spacers on the device.
  9. Ring Outdoor Security Cam Infrared Sensor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ring Outdoor Security Cam Infrared Sensor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ring Outdoor Security Cam Infrared Sensor Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the motherboard out with a plastic opening tool.
    • Flip the device over and then carefully press on the camera lens to remove the camera and the attached mother board from the device.
  10. Ring Outdoor Security Cam Infrared Sensor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a soldering iron to disconnect the connections.
    • Remove the infrared sensor and replace as needed.
WilliamB22
crwdns2935283:009/13/23crwdne2935283:0
968 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 6-2, Kilpatrick Fall 2023 crwdns2935289:0University of North Texas, Team 6-2, Kilpatrick Fall 2023crwdne2935289:0
UNT-KILPATRICK-F23S6G2
crwdns2942667:0crwdne2942667:0 237
