Right Temple
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Right Temple, Remove the screw covers: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Right Temple, Remove the screw covers: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to remove the six screw covers from the right temple.
  2. Right Temple, Unfasten the right temple: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Right Temple, Unfasten the right temple: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two right temple halves.
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the right hinge cover.
  3. Right Temple, Remove the outer hinge cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Right Temple, Remove the outer hinge cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Right Temple, Remove the outer hinge cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger in the gap between the right outer and inner hinge covers.
    • Slide the spudger along the gap to separate the clips securing the outer hinge cover.
    • Remove the outer hinge cover.
  4. Right Temple, Remove the outer temple: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Right Temple, Remove the outer temple: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Right Temple, Remove the outer temple: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger in the gap between the outer and inner temple.
    • Slide the spudger along the gap to separate the clips securing the outer temple.
  5. Right Temple: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Right Temple: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Right Temple: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the top of the outer temple out of its slot in the hinge.
  6. Right Temple: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Right Temple: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Tesa 61395 Tape
    $6.99
    • The speaker is lightly adhered to the outer temple.
    • Rotate the outer temple towards you to access the speaker.
    • Slide the flat end of a spudger under the speaker to separate its adhesive.
    • During reassembly, if your speaker adhesive isn't sticky, use double-sided tape to re-adhere the speaker to the outer temple.
  7. Right Temple: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Right Temple: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Right Temple: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Thread the outer temple off of the USB‑C cable and remove it.
  8. Right Temple: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Right Temple: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the inner temple out of its slot in the hinge and remove it.
  9. Right Temple, Peel the hinge tape: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Right Temple, Peel the hinge tape: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to peel back the black tape covering one of the inner hinge cover screws.
  10. Right Temple, Unfasten the inner hinge cover: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the two screws securing the inner hinge cover:
    • One 3.1 mm‑long screw
    • One 4.9 mm‑long screw
  11. Right Temple, Remove the inner hinge cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Right Temple, Remove the inner hinge cover: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Right Temple, Remove the inner hinge cover: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the inner hinge cover off its groove in the frame.
    • Thread the inner hinge cover off of the USB-C and speaker cables and remove it.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
168,721 crwdns2915208:0crwdne2915208:0
crwdns2935297:0769crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,151crwdne2935297:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 53
