Right‑Side Inner Shell Removal
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Right‑Side Inner Shell Removal, Before you begin: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Right‑Side Inner Shell Removal, Before you begin: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Right‑Side Inner Shell Removal, Before you begin: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before starting your repair:
    • Shut down your PlayStation and unplug all cables and accessories.
    • Remove any stands supporting your console and lay it down so the right side is facing up.
  2. Right‑Side Inner Shell Removal, Remove the console covers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Right‑Side Inner Shell Removal, Remove the console covers: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Right‑Side Inner Shell Removal, Remove the console covers: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Each console cover is secured with hooks along the rear edge and clips along the front edge.
    • To remove a cover, firmly pull up the front edge to release the clips.
    • You'll hear distinct "pops" as the clips release.
    • Remove the cover.
  3. Right‑Side Inner Shell Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Right‑Side Inner Shell Removal: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Right‑Side Inner Shell Removal: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the same process to remove the three remaining covers.
    • To reinstall a cover, place the hooks into their cutouts along the rear edge and firmly press the front edge of the cover into place to re‑engage the clips.
  4. Right‑Side Inner Shell Removal, Remove the expansion slot cover screw: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Right‑Side Inner Shell Removal, Remove the expansion slot cover screw: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    FixMat
    $36.95
    • Use a Phillips screwdriver to remove the 17.1 mm‑long screw securing the expansion slot cover.
  5. Right‑Side Inner Shell Removal, Remove the expansion slot cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Right‑Side Inner Shell Removal, Remove the expansion slot cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Right‑Side Inner Shell Removal, Remove the expansion slot cover: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to lift the expansion slot cover near the notch by the screw hole and remove it.
  6. Right‑Side Inner Shell Removal, Remove the fan cables cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Right‑Side Inner Shell Removal, Remove the fan cables cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Right‑Side Inner Shell Removal, Remove the fan cables cover: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Tesa 61395 Tape
    $5.99
    • Use your fingers to remove the plastic cover hiding the fan cables connector.
    • The cover is secured with light adhesive.
    • During reassembly, press the piece of plastic back into place to secure it with the leftover adhesive. If it isn't sticking, use strips of double-sided tape to secure it.
  7. Right‑Side Inner Shell Removal, Free the fan cables: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Right‑Side Inner Shell Removal, Free the fan cables: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the fan cables out from under their plastic clip on the frame.
  8. Right‑Side Inner Shell Removal, Disconnect the fan: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Right‑Side Inner Shell Removal, Disconnect the fan: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Right‑Side Inner Shell Removal, Disconnect the fan: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Firmly grip the fan cables' white connector head and pull it straight up and out of its socket.
    • If you're having trouble, grip the cables just above the connector head, and gently pull.
    • During reassembly, align the connector over its socket and push down on the edges with the flat end of a spudger until it slides fully into its socket.
  9. Right‑Side Inner Shell Removal, Remove the fan screws: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Right‑Side Inner Shell Removal, Remove the fan screws: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T8 Torx Security screwdriver to remove the four screws securing the fan:
    • One 31.7 mm‑long screw
    • Two 21.5 mm‑long screws
    • One 11.5 mm‑long screw
  10. Right‑Side Inner Shell Removal, Remove the fan: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Right‑Side Inner Shell Removal, Remove the fan: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to grab the fan by its vents and lift it straight up to remove it.
    • During reassembly:
    • This is a good point to clean the fan. Use a clean cloth and some compressed air to remove any dust or dirt.
    • Insert the fan so its cables are near their connector.
  11. Right‑Side Inner Shell Removal, Peel up the tamper evident sticker: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Right‑Side Inner Shell Removal, Peel up the tamper evident sticker: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  12. Right‑Side Inner Shell Removal, Remove the fan grille: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Right‑Side Inner Shell Removal, Remove the fan grille: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Right‑Side Inner Shell Removal, Remove the fan grille: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to unclip and remove the plastic grille near the fan recess.
  13. Right‑Side Inner Shell Removal, Remove the right‑side inner shell screws: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Right‑Side Inner Shell Removal, Remove the right‑side inner shell screws: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T8 Torx Security screwdriver to remove the 10 screws securing the right‑side inner shell:
    • Four 18.8 mm‑long screws
    • Two 18.6 mm‑long screws
    • Four 31.7 mm‑long screws
  14. Right‑Side Inner Shell Removal, Remove the right‑side inner shell: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Right‑Side Inner Shell Removal, Remove the right‑side inner shell: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the right‑side inner shell straight up and remove it.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
118.608 crwdns2915208:0crwdne2915208:0
crwdns2935297:0837crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.567crwdne2935297:0
crwdns2942667:0crwdne2942667:0 72
