Rienok S1 Mini Battery Replacement
  1. Rienok S1 Mini Battery Replacement, Grille: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rienok S1 Mini Battery Replacement, Grille: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Start with the buttons panel up and facing you.
    • Wedge in one iFixit opening pick, and apply outward pressure to pop out one side of the grille.
    • Using a second pick, slide from the first pick towards the opposite end until one whole side is popped out.
  2. Rienok S1 Mini Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While holding the other side open so it doesn't snap closed, wedge in one opening pick into one corner of the closed side.
    • Apply outward pressure until that side also pops out.
    • Using a second opening pick, slide from the first one until both sides have popped out.
  3. Rienok S1 Mini Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull outward on one end, while holding the other open.
    • Pull in the opposite direction on the top or bottom rings while slightly rotating the center until the whole grille is removed.
  4. Rienok S1 Mini Battery Replacement, Top and Bottom Rings: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rienok S1 Mini Battery Replacement, Top and Bottom Rings: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge an iFixit opening pick into the space between the ring and the housing.
    • Insert a Jimmy into the gap created.
    • Apply an out-and-upward pressure with the Jimmy to disconnect the plastic clips surrounding the ring.
    • Work the Jimmy around the ring, disconnecting the clips along the way until they are all disconnected.
    • It may help to insert additional opening picks as you go to keep the previous clips from reconnecting.
  5. Rienok S1 Mini Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rienok S1 Mini Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the first ring, turn the device to the other side.
    • Repeat the previous step to remove the second ring.
  6. Rienok S1 Mini Battery Replacement, Buttons Panel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rienok S1 Mini Battery Replacement, Buttons Panel: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six 8 mm black screws using a Phillips #000 screwdriver.
  7. Rienok S1 Mini Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rienok S1 Mini Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the screws removed, grasp the buttons panel and pull it off.
  8. Rienok S1 Mini Battery Replacement, Case: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rienok S1 Mini Battery Replacement, Case: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rienok S1 Mini Battery Replacement, Case: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the device with the speakers facing up.
    • Remove the six 10 mm silver screws connecting the two halves of the case with a Phillips #1 screwdriver.
  9. Rienok S1 Mini Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rienok S1 Mini Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rienok S1 Mini Battery Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a Jimmy into the seam between both halves.
    • Lightly twist the Jimmy until a small gap appears.
    • Work the Jimmy across the length creating and widening the gap as you go across.
    • With the gap across the whole length, grasp both halves and lightly pull apart.
    • DO NOT yank apart; the two halves are still connected by a few cords.
  10. Rienok S1 Mini Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rienok S1 Mini Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the foam glue from the plugs.
    • Grip the plugs with your fingernails, and gently pull each plug until all three are disconnected.
    • If replacing the case, pull on the battery and motherboard, and they will come right out.
  11. Rienok S1 Mini Battery Replacement, Battery: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rienok S1 Mini Battery Replacement, Battery: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rienok S1 Mini Battery Replacement, Battery: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently grasp the battery and slowly and carefully remove it.
    • Remove the foam glue, and unplug the battery to disconnect it.
Bryan Isiordia
crwdns2935283:002/20/25crwdne2935283:0
73 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 7-1, Kershman Spring 2025 crwdns2935289:0CSU Los Angeles, Team 7-1, Kershman Spring 2025crwdne2935289:0
CSULA-KERSHMAN-S25S7G1
crwdns2936753:030crwdne2936753:0 56
crwdns2942667:0crwdne2942667:0 172
