Ridgid R82005 Motor Replacement
  1. Ridgid R82005  Motor Replacement, Housing Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
  2. Ridgid R82005  Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the metallic Housing Connecting clip out with flat side of the plastic opening tool.
    • Eject battery before attempting this step.
  3. Ridgid R82005  Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ridgid R82005  Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the top half of the Housing Assembly.
  4. Ridgid R82005  Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ridgid R82005  Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp carefully the top and bottom of drill components.
    • LED light needs to be manually removed.
    • Lift and transfer, as a whole, the drill components from the old housing assembly to the new housing.
    • Make sure all drill components fit properly in the grooves of new Housing Assembly.
  5. Ridgid R82005  Motor Replacement, Motor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ridgid R82005  Motor Replacement, Motor: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ridgid R82005  Motor Replacement, Motor: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the two pins through the motor assembly.
    • We used an Alan wrench to push the pins through, but any small tool will do.
    • Unsolder the wires from the back of the motor to free the motor from the trigger assembly.
    • To learn how to solder, check out the How to Solder and Desolder Connections guide.
    • Make sure all drill components fit properly in the grooves of the Housing Assembly.
Andrew McPherson
crwdns2935283:002/14/19crwdne2935283:0
479 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G2, Leahy Spring 2019 crwdns2935289:0USF Tampa, Team S1-G2, Leahy Spring 2019crwdne2935289:0
USFT-LEAHY-S19S1G2
crwdns2942667:0crwdne2942667:0 1,135
