Ridgid R2601 Motor Assembly Replacement
  1. Ridgid R2601 Motor Assembly Replacement, Top Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four M3.5 x 16 mm screws from the top cover using a Torx T10 screwdriver.
  2. Ridgid R2601 Motor Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull off the top cover.
  3. Ridgid R2601 Motor Assembly Replacement, Bearing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the sander upside down so that the base faces you.
    • Remove the four 6.4 mm screws from the bottom of the base using a Torx T-25 screwdriver.
  4. Ridgid R2601 Motor Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the base.
  5. Ridgid R2601 Motor Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 10 mm screw from the center of the bearing using a Torx T-20 screwdriver.
  6. Ridgid R2601 Motor Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bearing.
  7. Ridgid R2601 Motor Assembly Replacement, Brake: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 16mm screws from the side of the sander using a Torx T20 screwdriver.
  8. Ridgid R2601 Motor Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a metal spudger to open the sander's plastic housing.
  9. Ridgid R2601 Motor Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plastic housing.
  10. Ridgid R2601 Motor Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the brake from its slot in the housing.
  11. Ridgid R2601 Motor Assembly Replacement, Motor Assembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the metal flywheel.
  12. Ridgid R2601 Motor Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the sander so that the top is facing you.
    • Remove the power switch.
  13. Ridgid R2601 Motor Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ridgid R2601 Motor Assembly Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T20 Torx screwdrivers to remove the four 11.11mm screws from the motor housing.
    • Use a T25 Torx screwdriver to remove the two 12.7mm screws next to the leads.
  14. Ridgid R2601 Motor Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Use a 2.5mm flathead screwdriver to loosen but not remove the screws holding the wiring leading to the speed controller.
  15. Ridgid R2601 Motor Assembly Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the leads.
  16. Ridgid R2601 Motor Assembly Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motor housing.
  17. Ridgid R2601 Motor Assembly Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motor.
Gary Garner
crwdns2935283:010/03/19crwdne2935283:0
295 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S1-G24, Eggleston Fall 2019 crwdns2935289:0The Citadel Military College of South Carolina, Team S1-G24, Eggleston Fall 2019crwdne2935289:0
CMCSC-EGGLESTON-F19S1G24
crwdns2942667:0crwdne2942667:0 1,071
