If your Ridgid R175RNE nailer is firing sluggishly or not at all, then the air-line connector may need to be replaced.
The air-line connector is used to connect the nailer to your air supply, so that the nailer may function.
Caution: Turn off and remove the air supply before beginning this guide.
Use a 5/32" Allen wrench to remove all three 25 mm screws that secure the swivel air plug.
Remove the swivel air plug.
