This guide is for Brush replacement on the Rigid JobMax R2851 Series B. This would be helpful if you have been noticing slowed rotation speeds or sudden starting and stopping of the tool. If the tool has stopped working completely and you find the motor is in good condition.
This repair requires minimal tools listed in the guide, and can be done in a short amount of time. Additionally you should remember to unplug your device before starting any repairs to avoid risk of being electrocuted.
Orient the device so that the trigger is facing downwards.
Place your thumb and index finger on the two buttons located on the head of the tool.
Press the two buttons in and pull the head of the tool off.
Loosen all eight 15mm T10 Torx screws.
Orient the device so that the cord end is facing upwards.
Take a small cutting tool, and cut down the seam in the back, ensuring that you only cut the sticker.
Completely remove all eight 15mm T10 Torx screws.
Pull the device case off, gripping at the back of the case and rotating it towards the front of the device.
Once the device has been separated gently pull on the trigger assembly to remove it from one side of the case.
Grip each of the sides of the two green circuit boards and slide them up.
Grip each side of the device trigger, and slide it up.
Grip the motor firmly and pull towards the back of the tool, rotating back forth until the motor is free.
Pinch the brush and pry upward away from the center of the part to remove from the device.
Firmly hold the brush in one hand and pull at the base of the wire to disconnect.
Anyone know where I can buy replacement burshes? Great write up! Thanks
