This guide is for the directional button on the Rigid JobMax R2851 Series B. This would be helpful if you have been noticing sudden change in direction of motor operation. If the button has stopped working completely and you find the motor and the button are in good condition.
This repair requires minimal tools listed in the guide, and can be done in a short amount of time. Additionally you should remember to unplug your device before starting any repairs to avoid risk of being electrocuted.
Orient the device so that the trigger is facing downwards.
Place your thumb and index finger on the two buttons located on the head of the tool.
Press the two buttons in and pull the head of the tool off.
Loosen all eight 15mm T10 Torx screws.
Orient the device so that the cord end is facing upwards.
Take a small cutting tool, and cut down the seam in the back, ensuring that you only cut the sticker.
Completely remove all eight 15mm T10 Torx screws.
Pull the device case off, gripping at the back of the case and rotating it towards the front of the device.
Once the device has been separated gently pull on the trigger assembly to remove it from one side of the case.
Grab the trigger mechanism, and lift it up and away from the device.
Slide and wiggle the metal rod holding down the directional button.
Slide the directional button up and out of the device.
Hole and slot for reassembly
