Ridgid GEN5X R8642 Gear Assembly Replacement
  1. Ridgid GEN5X R8642 Gear Assembly Replacement, Gear Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plastic tab holding the handle cover in place by prying upward with the spudger until the tab pops off.
  2. Ridgid GEN5X R8642 Gear Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the handle cover by pulling it towards the front of the saw.
    • The grip can sometimes become stuck and may require a decent amount of force to remove.
  3. Ridgid GEN5X R8642 Gear Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ridgid GEN5X R8642 Gear Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T20 Torx screwdriver to remove the nine M4 X 16mm screws from the plastic housing.
  4. Ridgid GEN5X R8642 Gear Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a JIS #1 screwdriver to remove the two M4 x 25mm screws on both sides of the metal housing.
  5. Ridgid GEN5X R8642 Gear Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one half of the plastic housing using a spudger so that the internal system is exposed.
  6. Ridgid GEN5X R8642 Gear Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ridgid GEN5X R8642 Gear Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the one 16mm T20 screw that holds the grip support onto the saw.
  7. Ridgid GEN5X R8642 Gear Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ridgid GEN5X R8642 Gear Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ridgid GEN5X R8642 Gear Assembly Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the five T20 Torx screws from the gear assembly cover and pull the cover off.
  8. Ridgid GEN5X R8642 Gear Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ridgid GEN5X R8642 Gear Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the motor making sure not to harm any of the wires that are attached. Place motor gently out of the way.
  9. Ridgid GEN5X R8642 Gear Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ridgid GEN5X R8642 Gear Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ridgid GEN5X R8642 Gear Assembly Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the orbital switch by pulling straight up on it.
    • Be careful to not lose the spring and pin that is inside of the switch.
  10. Ridgid GEN5X R8642 Gear Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ridgid GEN5X R8642 Gear Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ridgid GEN5X R8642 Gear Assembly Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the gear assembly by pulling it straight up.
  11. Ridgid GEN5X R8642 Gear Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ridgid GEN5X R8642 Gear Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ridgid GEN5X R8642 Gear Assembly Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the pin holding the metal guide housing in place.
    • Slide the metal guide housing back off the gear assembly.
  12. Ridgid GEN5X R8642 Gear Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ridgid GEN5X R8642 Gear Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the guide bushing by pulling up on it.
    • Then slide the pin out that holds the gear assembly and blade clamp assembly.
  13. Ridgid GEN5X R8642 Gear Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the blade clamp assembly off the gear assembly.
    What about the smaller pinion gear at the end of the motor? Assuming the big gear is worn should the smaller gear be worn too. Is the smaller gear replaceable? Is it typical to replace the big gear without replacing the smaller one?
    Charlie Fisenne - crwdns2934203:0crwdne2934203:0
Josh Wagoner
crwdns2935283:002/12/19crwdne2935283:0
217 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team S1-G3, Virtue Spring 2019 crwdns2935289:0Western Carolina University, Team S1-G3, Virtue Spring 2019crwdne2935289:0
WCU-VIRTUE-S19S1G3
When reassembling with new gear, does gear needs to be greased?
Syoma Zv - crwdns2934203:0crwdne2934203:0
When reassembling after disassembly, cleaning gear case and all parts, how much is the right amount of grease for this gear box.
R Bulley - crwdns2934203:0crwdne2934203:0
Can anyone tell me how much grease to put in the gear case of a Ridgid R8642 Reciprocating saw when gear case is empty and clean.
crwdns2942667:0crwdne2942667:0 2,309
