Ridgid GEN5X R8642 Motor Replacement
  1. Ridgid GEN5X R8642  Motor Replacement, Motor Replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plastic tab holding the handle cover in place by prying upward with the spudger until the tab pops off.
  2. Ridgid GEN5X R8642  Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the handle cover by pulling it towards the front of the saw.
    • The grip can sometimes become stuck and may require a decent amount of force to remove.
  3. Ridgid GEN5X R8642  Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ridgid GEN5X R8642  Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T20 Torx screwdriver to remove the nine M4 X 16mm screws from the plastic housing.
  4. Ridgid GEN5X R8642  Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a JIS #1 screwdriver to remove the two M4 x 25mm screws on both sides of the metal housing.
  5. Ridgid GEN5X R8642  Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ridgid GEN5X R8642  Motor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove one half of the plastic housing using a spudger so that the internal system is exposed.
  6. Ridgid GEN5X R8642  Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ridgid GEN5X R8642  Motor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the one 16mm T20 screw that holds the grip support onto the saw.
  7. Ridgid GEN5X R8642  Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ridgid GEN5X R8642  Motor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ridgid GEN5X R8642  Motor Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the five T20 Torx screws from the gear assembly cover and pull the cover off.
  8. Ridgid GEN5X R8642  Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ridgid GEN5X R8642  Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the motor making sure not to harm any of the wires that are attached. Place motor gently out of the way.
  9. Ridgid GEN5X R8642  Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plastic wire covers to the red and black connections on the switch assembly.
    • When you remove the wire covers, you should be able to see the solder on the wires.
    • Desolder the connections on both the red and black wire using a soldering iron.
    • Once the solder is removed, pull out the wires with the battery port attached to the wires.
  10. Ridgid GEN5X R8642  Motor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the soldered connection from the switch assembly.
  11. Ridgid GEN5X R8642  Motor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ridgid GEN5X R8642  Motor Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Solder both connections of the new motor replacement to the switch assembly.
To reassemble your device follow these instructions in reverse order.
Mauricio Moreno
crwdns2935283:002/12/19crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team S1-G3, Virtue Spring 2019 crwdns2935289:0Western Carolina University, Team S1-G3, Virtue Spring 2019crwdne2935289:0
WCU-VIRTUE-S19S1G3
crwdns2942667:0crwdne2942667:0 610
