Ridgid GEN5X R8611506 Gears Replacement
  1. Ridgid GEN5X R8611506 Gears Replacement, Outer Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ridgid GEN5X R8611506 Gears Replacement, Outer Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Orient the drill to have the side with the screws facing up.
    • Using the Torx T10 screwdriver, remove the eight 4.0mm screws from the face of the drill.
  2. Ridgid GEN5X R8611506 Gears Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ridgid GEN5X R8611506 Gears Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ridgid GEN5X R8611506 Gears Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the drill to where the back is facing up.
    • Using a Torx T10 screwdriver, remove the four 6.0mm screws that attach the back piece to the drill.
    • Remove the back piece of the drill using the iFixit opening tool.
  3. Ridgid GEN5X R8611506 Gears Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ridgid GEN5X R8611506 Gears Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Orient the drill to where the chuck is facing up.
    • Using the Torx T15 screwdriver, remove the four 8.0mm screws from the front of the drill.
  4. Ridgid GEN5X R8611506 Gears Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ridgid GEN5X R8611506 Gears Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Orient the drill so the side with the screw holes is facing up.
    • Use a plastic opening tool to gently pry the face off of the drill.
    • Remove the face completely from the drill.
  5. Ridgid GEN5X R8611506 Gears Replacement, Speed Selector Switch: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the selector switch.
    • Unhook the selector switch from the small silver wire located near the top of the drill.
  6. Ridgid GEN5X R8611506 Gears Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the speed selector switch from the case housing.
  7. Ridgid GEN5X R8611506 Gears Replacement, Gears: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the motor and chuck out of the drill casing.
  8. Ridgid GEN5X R8611506 Gears Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ridgid GEN5X R8611506 Gears Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Orient the motor and chuck to where the back of the motor is facing up.
    • Using a Phillips #0 screwdriver, remove the four 5.0mm screws that connect the motor to the chuck.
  9. Ridgid GEN5X R8611506 Gears Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ridgid GEN5X R8611506 Gears Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull apart the motor from the chuck to expose the gears.
    • Remove the four gears located within the motor/chuck housing.
Harrison Essary
crwdns2935283:002/05/19crwdne2935283:0
611 crwdns2915208:0crwdne2915208:0
Appalachian State University, Team S2-G4, Menagarishvili Spring 2019 crwdns2935289:0Appalachian State University, Team S2-G4, Menagarishvili Spring 2019crwdne2935289:0
APSU-MENAGARISHVILI-S19S2G4
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 808
